96 Achieva 2.4L A/C problems
primercaRCH
01-11-2005, 03:38 PM
Trying to locate the low or high pressure switches or cycling switch
to by pass to get the comp to run and accept ? ( more ) freon.
There is 12 volts running to the clutch when the system is on and no voltage when the system is off. I would like to run a hot wire to the clutch ( without burning it up ) and see if will run for a longer time.
And info
Randy
And info
Randy
