rear disc convertion help
big bad mohawk guy
01-11-2005, 10:45 AM
how exactilly do you do a rear disc conversion on a hf.i would like to know the best way do this.
amy@af
01-11-2005, 10:59 AM
kris
01-11-2005, 11:11 AM
Have fun.
Sparsky
01-11-2005, 10:28 PM
I just did the swap about 2 weeks ago on my 88 CRX SI. Hardest part was the E-Brake cables and the 4040 prop valve.
crv-tec
03-21-2005, 08:17 PM
Will the 4040 prop valve work with the HF front brakes? I plan to do this conversion as soon as I get my bonus from work, but wasn't sure if the valve would work with stock front brake lines. Also do you have to use the 90-93 teg's brake lines?
Scott82
03-21-2005, 09:25 PM
i have a book that walks you thru 94-2000 teg brake sys. is a direct bolt up if you get the master cylinder, booster, brake lines, and emergency brake cable. Its a book called honda engine swaps and oem upgrades and i got it off amazon.com. it goes thru a lot of differ swaps and conversions. Not real helpful on wiring but good w/ mechanical stuff
civickiller
03-22-2005, 01:02 AM
just get a 4th gen ex master cylinder
crv-tec
03-22-2005, 11:08 AM
Also will the 4040 prop valve work with LS brakes from a 90-93? I got a call last night for front LS brakes for 100...
