96Lumina sedan/wont shift at all...HELP
shroom59
01-10-2005, 09:09 PM
I have a 96 chevy lumina sedan, one day i had to rev it up just to get it to shift in order for it to even move, then only reverse ran and then nothing, fluid was a little discolored but not bad, changed filter and fluid, but still nothing, there was not grinding or vibrations or clatter before, just one day i had to rev it in order for it to shift. Any ideas, one person has told me, computer codes or soleinoid replacement, now i beleive its in the front of the engine on the drivers side, please help thanks......shur40k@yahoo.com :disappoin
fopu
01-10-2005, 09:16 PM
Don't take my words for granted as I don't know much about automatic transmissions but I would check first the vacuum modulator. If it's not that one, then prepare for the worse...
jeffcoslacker
01-11-2005, 06:04 AM
Fopu's right, sounds like the seal blew in the modulator. That, or the line to it cracked. It is very easy to change, if you know where and what you are looking at. It just has one bolt that holds a clamp that keeps the unit in the tranny case. It is on the front, driver's side, down low, will be a small metal "can" about the size roughly of a 35mm film canister, maybe a little shorter, with a colored stripe around it. It has one vacuum line that attaches to it. This is usually a metal line, with rubber hose at the ends. It goes up to the intake manifold on the motor. Check both rubber ends for cracking, or swelling that could make it suck air. If that seems good, pull the line off at the tranny end. If any fluid runs out, the modulator is blown for sure. There are only about $10 or $12, I think. It would be worth trying, even if there is no obvious problem with it. Good luck!
jeffcoslacker
01-11-2005, 08:40 AM
Didn't mean to mislead you, but the modulator on these doesn't look the same as the ones I remember. It is larger, and odd shaped. But still works the same. I took a picture, to show you the location.
http://images5.theimagehosting.com/location.1.JPG
http://images5.theimagehosting.com/modulator.JPG
shroom59
01-11-2005, 09:37 PM
hey thanks for the pic, man i had this thing off already and yes some trannie fluid came out of the modulator alright, man car has been laid up for 4 months , well let you know this weekend whats up, then i have to replace the right rear control arm, kid put a jack up under it, man no wonder i am all squirrely on the road last year
