Lift
3kgt95
01-09-2005, 01:43 PM
hey guys im new to this forum and was wondering if you guys or girls have any pictures of your trucks with lifts and if u do post them i think everyone would like to see your trucks including me. i was also wondering if i had a 3 or 4in. lift what would be some great tires.(how much does it cost to get a 3 or 4in lift oh yeah does the z71 mean its 4x4 sorry dont know a lot)
Ape0r
01-09-2005, 03:24 PM
Z71 = 4x4 w/ better shocks than regular 4x4.
3" body lift ~$300-350
4" Suspension lift ~$1200-1600? Suspension lifts for this truck are pricey because they generally require a subframe. 6" kits generally don't cost much more than 4".
Labor will cost you an arm and a leg on a lift, that is, unless you plan on doing it yourself. A body lift can be done in an afternoon, a suspension lift will take a couple of days, IMO.
3kgt95
01-09-2005, 03:40 PM
why is there such a big differnece in price from a 3" to a 4" lift.
kenny-1907
01-09-2005, 03:43 PM
The 3" price he listed is for a body lift and the 4" price is for a suspension lift.
Ape0r
01-09-2005, 04:43 PM
Yeah, you don't really see many, if any, suspension lifts that are less than 4". Likewise, I haven't seen many body lifts over 3".
The body lift just puts spacers between the frame and the cab/cargo box, whereas the suspension lift actually raises it up using springs/lift blocks/a subframe.
It seems to me that a body lift might be kind of unsafe in an accident, what with bolts having more leverage on them and all. Just a thought. Of course this isn't to say that accidents are safe to begin with =).
mjgjr72
01-09-2005, 05:11 PM
6" suspention lift $1500, installed myself
315/75 16 bfg tires and american racing aluminum rims $1800 for 5, installed myself
if you do a suspention might as well do a 6" it is almost the same amount of work
http://www.carsnrides.com/Profile.aspx?vid=1406
or check the gallery on bottom of post
airjam18
01-09-2005, 08:24 PM
Body lifts generally are used to bump up a tire size or two, mostly for aesthetics. Suspension lifts are more functional and definitely a bit more expensive. A body lift kit is generally $200-$300 while suspension kits usually go for $1200 and up. Labor is expensive on both. I've got a 6" ProComp suspension lift on my z71. I'm still running 33" tires(285/75/16) as i am waiting for the tires to wear down a little more before replacing them with 35" tires. You can check out some pics here: http://www.cardomain.com/memberpage/660426
NWChevyGuy
01-09-2005, 10:19 PM
Here is what a 6" suspension lift with 35" tires looks like.
3kgt95
01-09-2005, 11:05 PM
do u have any more pictures nwchevyguy? airjam18 i love your truck once u get the 35in" tires post them on this thread or cardomain. I know this is probably a dumb question because i dont know about trucks that much because i currently own a mit. 3000gt but what suspension kits are mostly reccommended and where do u buy them.
jeverett
01-10-2005, 07:27 AM
I prefer Fabtech or RCD racing....thats just my prefrence though.
3kgt95
01-10-2005, 03:09 PM
storm442 so u have a 6" suspension kit and a 4" body lift
3kgt95
01-10-2005, 03:12 PM
does anybody have pictures of like a 4" suspension lift
Ape0r
01-10-2005, 03:54 PM
Storm's truck also appears to be a little higher than airjam's because it is the 3/4-ton, which is higher to begin with.
3kgt95
01-10-2005, 06:56 PM
storm what kind of tires are those. could u explain what rubbing means. so all u have to do to get a suspension kit is buy the kit online or at a store and get it done at like a exhaust place?
TexasF355F1
01-10-2005, 07:40 PM
My buddy has a 99 Silvy with a pro-comp 6" lift, 18's and 36"ers. Slight rub when turning but not much. Rides pretty nice too.
airjam18
01-10-2005, 07:55 PM
storm442, you got a beautiful truck. Nothign look sas good as an HD with a lift. The heavy duties will always look bigger no matter if its chevy, ford, or dodge because the heavy duty's come with a thicker frame. i've seen stock trucks that are nearly as big as mine. Another thing is that it is important to remember that EVERY truck is different. Could be the same make and model but they each come a little different and after time they wear differently. One of my buddies has the same truck as myself and is running 36" tires with a 6" lift and torsion bar crank. Another friend with the same truck could only fit 35" on backspaced rims without rubbing.
3kgt95 : "rubbing" refers to the tires rubbing up against steering or bumper components when turning due to too large a tire or lack of backspacing on the rim.
3kgt95
01-11-2005, 10:34 PM
i didn't want to start a new thread so ill just ask it here. I was wanting to know if you could bye like a black grille emblem to replace the stock one. and where u could get one because i saw it on a truck and liked it.
steve v
01-11-2005, 11:49 PM
Hey, new to the board. Here's a pic with a 6 inch lift and 33's
http://img.photobucket.com/albums/v17/stevev/truck/newrims.jpg
3kgt95
01-12-2005, 04:23 PM
can anyone answer my question.
jeverett
01-13-2005, 07:02 AM
Yes, you can get one. Look on e-bay. They usually have lots of them.
