what is this for?
off_da_wall4u2nv
01-09-2005, 07:25 AM
i have basically stock everything. there is a metal cover over my headers and there is a hose connecting the cover to the air intake, whats that for? and could i take and leave it off? theres a pic in my gallery with me pointing to it.
97integrals
01-09-2005, 11:36 AM
It is a heat shield it attempts to keep the heat from the exhaust manifold from heating up the engine bay. You can remove it if you want but I would leave it in place.
off_da_wall4u2nv
01-10-2005, 03:03 AM
so if i were to put a cold air intake in what would be the point of it cause aint the hose thats connected to that cover just sucking hot air into the air intake?
Mannyb18b
01-10-2005, 03:29 PM
ive never heard of a hose connecting to a heat shield?
boosted k20
01-10-2005, 04:24 PM
that looks more like the EGR valve (exhasut gas return valve) pipe. Does it screw into the exhaust manifold? the EGR valve sends back some of the exhaust gas back into the engine in order to burn up any gas that wasnt burn up in the original combustion. it's strictly meant for emissions purposes
off_da_wall4u2nv
01-10-2005, 09:29 PM
the heat shield is just bolted onto the exhaust manifold. and the hose is connected to the heat shield by a little metal prong which connects the heat shield to the air intake. so to answer your question no it does not screw into a pipe..
off_da_wall4u2nv
01-10-2005, 09:31 PM
in my gallery i have a few pics with me holding and pointing to where the hose connects, if i were to flip the heat shield over all you would see is the hole to where the hose connects, its not connected to anything else.
hueroloco
01-10-2005, 11:20 PM
that's your TAC tube. When your car is warming up, it heats up the intake air using the heat from the exhaust manifold to improve fuel vaporization and mixture distribution.
If you take it off you'll probly never even notice it was gone.
dcaegis
01-10-2005, 11:43 PM
^ ding ding thats correct. everyone else was way off
although removing it may cause driveablity problems in cold weather when the engine is cold.
off_da_wall4u2nv
01-11-2005, 03:00 AM
so why dont all the other integra s have it , wheres theres located
off_da_wall4u2nv
01-11-2005, 03:11 AM
well anyways i went to the parts store and found that they want 250$ for an o2 sensor for my ``1994 honda integra sohc automatic 4 dr`` whats the deal with that, are there any other honda vehicles that have the same engine as mine??? anybody know
boosted k20
01-11-2005, 09:41 AM
WTF SOHC 94 integra? is ur car JDM?????
u can get a regular BOSCH O2 sensor for $50-60 from autozone. all u need to do if follow the directions on how to wire it up to ur specific car. good luck
off_da_wall4u2nv
01-11-2005, 06:49 PM
yeah im over in japan
