No washer fluid/No noise
lindchad
01-08-2005, 09:19 PM
My washer fluid is no longer running when I depress the switch. There is washer fluid in the reservior and the wipers work fine on all speeds. There is no noise coming from the motor. Is there a fuse to replace for this because it isn't clear in the owners manual? Or is this something else? ANY suggestions are GREATLY appreciated? Also, what service manual is commonly used for this vehicle? Thanks so much in advance!
kustomkid54
01-08-2005, 10:32 PM
Try pulling the line off and blow thru it. That should clear any stopage in it. (Is that a word?)
http://img.photobucket.com/albums/v425/kustomkid54/logo9.jpg
1997GrandPrix
09-25-2005, 02:31 PM
Same problem here... Check to see if the pump is working. Unplug the pump, and bypass the fuses and everything. Run wires from pump to battery. I did so with mine, and found the pump works fine. Which means it's an electrical problem. I am still working on it, but have not found the fuse yet. Let me know if you find anything.
gtp'n
09-26-2005, 10:08 AM
Had the same problem with mine. I replaced the pump with one I got from Napa for like $15. Took about 1/2 an hour to replace. Now she is back to normal
Blown_GP
09-27-2005, 07:40 PM
I had the same problem with both my 98 and 99 GTP's, I just replaced the pump in both and they worked. Payed like $15 at Autozone.
Just take off the passenger side tire and remove the lineing and its right there.
