fuel injector fuse blown
66brain
01-07-2005, 06:24 PM
Help, son's 1996 escort keeps blowing fuel injector fuse. Starts up with new one installed but seems to blow when he puts it in reverse. Any help would be great!
mlw35405
01-07-2005, 09:04 PM
Check the back up light switch and wires that are on the side of the transmission for a short.
A. Souphound
01-08-2005, 06:57 AM
What type of transmission, Auto or Manual?
Alvin
66brain
01-08-2005, 07:08 AM
It's auto tranny. I thought about that wiring but didn't think they would be fused in same circuit.Stranger things happen though..?
A. Souphound
01-08-2005, 09:49 AM
It's possible a cross short between the two circuits exists. I do not see a common circuit between the two.
The Gear Shift Neutral Switch activates the back-up lamp switch in 'R' (reverse). Are the back-up lamps working?
I would make sure the two symptoms are related by removing the fuse (the one that keeps blowing) and connect a test light or voltmeter in it's place to the fuse terminals. Wiggle the wiring around (side
to side) while watching the test light. If the bulb lights or you get a reading on the meter, there is a short to ground in that area. You can also shift into reverse and see if the test light comes on.
Alvin
