what to do now?
low&slo16
01-06-2005, 01:20 PM
Alrite i have a 98 civic ex (sohc) with i/h/e and i am lost on what to do now. i want to get some decent number outta it. well as many as i can with out a swap or fi. im not sure where to go next with it. my friend tells me to do fuel upgrades next. how much will i actuallly get outta them?
civickiller
01-06-2005, 01:39 PM
you can go with a cam, tb, intake mani. you will also need to more fuel if you do that because it will let in alot more air so it will run lean. this will give you some pretty good power dpeending on the cam you get
you can also get higher comp pistons. it would be good to go with the cam too.
if your really hardcore with getting power out of your sohc, have the motor sleeved and bored, you cant go big bore with stock sleeves
low&slo16
01-07-2005, 12:27 AM
i think i will go that rouut, thanks you. what cam would u suggest getting. also my friend has a set of prelde injector in his ex and i was wondering if they will do any good
civickiller
01-07-2005, 02:55 AM
i would suggest getting some kind of stage 2 cam with matching valvetrain
