97 grand cherokee
vrod
01-05-2005, 07:05 PM
first of all,thanks for past replies......now new problems! abs light on all the time,and drivers door does not unlock or lock with remote(just hear a faint electrical type click)all other locks work as normal....where do i begin,all fuses seem ok,all i found anyway........
JDPascal
01-05-2005, 09:01 PM
The ABS lite could be caused by a multitude of things. Better get the codes. best to have it scanned but Dale might know a way of digging them out with out taking it to a shop
If the drivers door lock works from the door switch, I would suspect the module or a wire coming from it thru the flex lume between the door and the jam.
JD
vrod
01-05-2005, 10:11 PM
any info to get the codes would be great(without paying the dealer a million dollars for it!....the driver door lock does not lock or unlock under any power(button or remote) have to do it manually,,do hear a faint clicking noise though,like a relay or something is triping.............
JDPascal
01-05-2005, 10:28 PM
I don't have the code for the dash lite and the DRBII scanner is the best for diagnosis. Some private shops have them but you will have to look hard for one that does.
Is the click comming from under the dash or in the door??
If it is under the dash, look for a broken wire - probably at the door jam or the door lock motor. If in the door, check the lock motor. It may have seized up or something.
JD
vrod
01-05-2005, 11:08 PM
ok ...thank you,i will try and find a local shop with a code finder...clicking is coming from the door so i will try and check the motor in the door..............
dksob81
01-06-2005, 10:34 AM
well like JD said, check the wires that run in between the door and the frame, they always get crimped and broke here, I had this happen to my power mirror on the passenger side, the wires got cruched and broken. you will c a rubber boot runnign from the jeep to the door in between the 2 hinges just pull the boot away and check the wires there.,
