firewall
hubin1
03-08-2002, 04:02 AM
sup guys
man need help to bring a wire from hood to inside..
how can i find a firewall to bring the wire in..
thanks guys
thanks guys
miker
03-08-2002, 11:45 AM
:silly2: whaaaazzzzzzzuuuuuuppppppp:silly2:
The firewall has rubber grommets with factory wiring going through them. You can carefully drill through or enlarge the opening to feed additonal wiring into the car / under the hood. Seal it with some RTV (silicon gell available at every autoparts store).
mtrai760
03-08-2002, 06:21 PM
There is a rubber grommet about 3 inches above the fuel filter. Remove that and route away... :D
hubin1
03-09-2002, 12:33 AM
do have to drill any holes???
where the wires will be coming out to??
thanks man..
you guys rock
thanks man..
you guys rock
mtrai760
03-09-2002, 05:04 PM
No, just pull the rubber plug out and route away. Its not very hard to pull out. The wires will come out right behind the dash on the drivers side.
:D
thanks man..
you guys rock
:D
thanks man..
you guys rock
