AIR DRIED BEEF DOG FOOD
1991 S-10 Blazer high Idle
1991Blazer4x4
01-04-2005, 02:59 PM
Hey all, I just put a new 4.3L into my '91 S-10 Blazer. I also installed new Edelbrock headers, water pump, radiator, exhaust including CAT and well, just about everything else. Anyways, I had no problems starting her up (besides putting gas into the truck). Well, with the truck turned on she idles at 2000 RPM even when she is at operating temperature. I am also getting quite alot of smoke coming from the motor. I do not see any exhaust leaks though. I am guessing this is just the coating on the headers. My question is...Is there a way to adjust the idle on a 4.3L motor to normal idle? What is the normal idle for this truck? My other question is has anyone installed headers and got alot of stinky smoke coming from the engine? How long did it smoke for? Any advice would be greatly appreciated. Thanks Alot.
BlazerLT
01-04-2005, 05:08 PM
Did you check the timing?
Is the engine new?
Did you clean and reinstall the IAC sensor?
Mikado14
01-04-2005, 06:52 PM
What engine was previously in your truck?
1991Blazer4x4
01-04-2005, 07:13 PM
I have adjusted the timing, the engine is a crate motor from Jasper, I installed everything that was previously on the old motor. I did not clean the IAC sensor though (what is the IAC sensor? What does it stand for?). I previously had the 4.3L in the truck. I put another 4.3L engine in.
Fireplug
01-04-2005, 07:47 PM
What about the o2 sensor where did you put it??
I=Idle A=AIR C= Control.
If its dirty it will give you a high idle
1991Blazer4x4
01-04-2005, 08:32 PM
I bought a new O2 sensor. I put it in the header pipe just before the CAT.
1991Blazer4x4
01-05-2005, 03:42 PM
Guess what guys....it was an easy fix that noone thought of. You all need to stop thinking of all of the difficult fixes. It was just the throttle cable. Apparently it got mis-adjusted during the tear down. Thanks for your help anyways.
BlazerLT
01-05-2005, 05:35 PM
And thank you for being an asshole and slamming our help.
We assumed the throttle cable would be installed properly, that is not our fault that it wasn't.
Fireplug
01-05-2005, 06:03 PM
Well Blazerlt I guess we (you and me and a few others) should stop waisting our time in here. Because we just arnt smart enough. This dude removes and installs a engine(good for him) then RUNS to this news group with a high idle problem instead of doing some very basic trouble shooting and rags on US for his mistake. Go figure.
Mikado14
01-05-2005, 07:26 PM
Ditto on the TWO previous posts. My sentiments. As Fireplug said, smart enough to change an engine but doesn't know how to adjust a throttle cable. So I wonder who the real asshole is.
(LT, one of the few times you will here a blue word from me.)
BlazerLT
01-05-2005, 07:29 PM
Hehehe, true.
Look at all three of us agree on something. This is a "blue" moon. ;)
