biger filter=more pover?
yuraRS
01-03-2005, 07:51 PM
hey guys, im about to buy new filter for my RS but just decided to ask if bigger filter will work better or worse or it doesnt really matter? I have cold air intake, and another question is: if i'll put bigger filter is it going to help reduce chances to get water into engine :)?
Thanku for any help
2of9
01-03-2005, 07:53 PM
it'll work and you'll get some but not alot of horses out of it. The chances of getting water is higher, but on a cold-air system, you'll need one of those things, kinda like a cushon that aborbs the water, right before the intake pipe goes down.
ashah000
01-04-2005, 07:17 AM
No need to make 2 posts
drdisque
01-04-2005, 07:42 PM
there's so little restriction on a regular intake, I don't think a larger filter would noticably reduce what little restriction there is.
guitarXgeek
01-04-2005, 11:30 PM
A larger filter on a turbo car will actually do some good. A guy on tuners a while back did some testing with filter sizes and concluded that larger filters actually help reduce pressure drop (in other words, you can't really go TOO big on a filter with a turbo). I can't remember exactly the details on his testing, so you may just have to search on tuners for it.
Just thought I'd throw that in as some food for thought ;) .
bad4g63
01-05-2005, 12:30 AM
a bypass valve, or cushion lol, will probably be necessary. it is on my acura, since the aem intake filter is about 4 inches from my tire, and i know plenty of cheap asshats that have hydrolocked their engine because they didnt spend the extra 45 bucks.
veilsidercng
01-10-2005, 04:47 PM
I heard if you put on the bypass then the cold air intake is only getting as much power as a ram air system, but just costs more. Is this true?
RSLaser
01-10-2005, 09:37 PM
Not so much a "bigger" filter, but a thinner filter, same diameter. thinner=less restriction, but higher chance of contaminants. And a thicker =more restriction, but less chance of contaminants.
96elipseracer
01-11-2005, 01:24 PM
Why don't you get the Ice Man C.A.I? You have the option 2 switch back and 4th! I had It...Loved it..Will get again!
