94 Bravada stalls, i need help!
punshrkng
01-03-2005, 11:01 AM
There is no real indication to when it will happen. It runs rough on long trips and refuses to start once it is turned off. Its been like that the past year and is getting worse. Now it dies while its running. The fuel system is fine and the fuel pump has been replaced recently.
Anyone know why its doing this?
Chris Stewart
01-03-2005, 03:58 PM
Is the Check Engine light on and if so, do you know how to pull trouble codes?
punshrkng
01-03-2005, 05:02 PM
no check engine light and no codes. All the seemingly obvious things arent working and its driving me nutty
Chris Stewart
01-04-2005, 02:45 PM
If it starts easy when cold, the problem may be the ignition coil or even a module in the distributor. Checking can be done with a service manual and digital volt/ohm meter...it's hard to explain which terminals to test.
punshrkng
01-16-2005, 08:58 PM
problem fixed!!! yeah! fuel pump was just barely pushing 50 psi replaced it and now I can feel the true power of my 4.3 :jump3:
Chris Stewart
01-17-2005, 01:09 AM
Glad it's ok now.
So your new pump was faulty?
