guage lighting??
BrentCosenza
01-03-2005, 03:43 AM
my guages work and everything the backlighting wont work and i cant see them at night can someone please help me?
LouieAWDTSi
01-05-2005, 09:46 PM
goto www.plymouthlaser.com ...read the install for boost gauge..i followed that and it worked out well...has good in depth directions and shows you each wire and color...good luck
BrentCosenza
01-10-2005, 02:44 AM
yeah but i am talking about stock guages not aftermarket i checked the fuses and its good but the lighting is screwed are you sure this site will help? i took the whole dash out to paint it the wiring is fine do i need new guages or lights or what?
DSMJohn1G
01-18-2005, 12:41 AM
It could just be your dimmer switch. When you unhooked the dash the connector may of not been clicked in all the way, make sure the connection between them is good. Just a suggestion, It will only take a couple of minutes.
