jacking points
tsi4444
01-01-2005, 08:07 PM
I have a 97 eagle talon tsi awd. Im about to put on a new exhaust system and I cant seem to figure out where to jack it up at. I want to put stands in the rear. Could you guys tell me were i should jack it up and put the stands. Thanks alot.
kwdiablo
01-08-2005, 11:44 AM
On my first gen, they're on the side. About six inches in from the bottom edge of the car, you'll see a skinny rib running from just in front of the rear tire, to just behind the front tire. This rib is on both sides.....hope thats clear enough.
joemathews
01-08-2005, 12:39 PM
Yep, about 6=8 inches from the wheel wells. You'll see a metal rail under the car, with a little indentation--that's the jacking point. Jack the car up a little to one side or the other on the rail if you're going to use a jackstand. And yes, the other parts of the rail might bend, but it won't hurt your car if you do it slowly ;)
tsi4444
01-08-2005, 05:31 PM
should i just jack it up on one side and place a stand there and then do the same to the other side?
GotGrip666
01-08-2005, 07:44 PM
on all cars there should be pinch weld right behind the front tires and in front or the rear tires
tsi4444
01-09-2005, 09:33 AM
ok thanks alot
