Bravada/Blazer/Envoy/Jimmy install
glehman85
01-01-2005, 02:52 PM
any suggestons to where as the very best and easiest way to install my power wire for my amp??? i am stumped on how to run it! thanks for the help everyone:smokin:
RickwithaTbird
01-02-2005, 05:37 PM
are you asking how to run the wire TO the inside of the car, or where to run it once its already in the car, or both? I dont have one but Id be willing to help you find a good way.
AndonD454
01-02-2005, 05:45 PM
drill a hole through the closest rubber grommet to the battery on the firewall.. make it just smaller than the power wire, then pull it through. run the wire under your carpet (along with RCAs and remote) to wherever you plan on mounting the amp. i like to stay on a far side of the interior (closest to the doors) just because i found it was easiest to run the wires without having to take out seats or work around them... hopefully pullign up the carpet is the hardest part for you (and its not that hard)
RickwithaTbird
01-02-2005, 05:59 PM
try to keep your power wire away from RCAs and remote wire. If the power wire is too close, it can cause noise. It wont always do that, but it definitely can.
