my car shouldnt be doing this
rendertrust
12-31-2004, 08:43 PM
she coughs out white smoke !! can somebody please tell me whats going on.... i hear her making a coughing noise and when i revv white smoke comes out .... stinks too
neogenesis
12-31-2004, 08:49 PM
You can find this answer from Mr. Search. He'll direct you to the right thread. I'm more than positive this has been discussed if not than head yourself to www.twinturbo.net where I know for sure they have.
RB25DETZ
12-31-2004, 09:58 PM
burning coolent will make white smoke. you might have oh i dunno a blown head gasket?
MikeMan
12-31-2004, 10:05 PM
Here is a quick (not comprehensive) rundown of different flavours of smoke out your exhaust, not just specific to zeds:
white == water. This could be a result of:
warped head
cracked head
blown head gasket
blue == oil. This could be a result of:
warped head
cracked head
blown head gasket
fucked piston rings
black == partially burnt fuel. This could be a result of:
faulty TPS (Throttle Position Sensor)
faulty O2 (oxygen) sensor
faulty FPR (Fuel pressure regulator)
faulty MAF (Mass Air Flow) / AFM (Air Flow Meter)
Incorrectly advanced/retarded ignition timing (Distributor or CAS - Crank angle sensor)
Incorrectly gapped spark plugs
warped head
cracked head
blown head gasket
warped head
cracked head
blown head gasket
fucked piston rings
rendertrust
12-31-2004, 10:29 PM
this guy will fix a warped/cracked head for me pretty cheap, hes my uncle.... however i would still need to find how much a head gasket costs and how much for a new head
were talking about 100$ for either one right
what does the coughing noise mean, it sounded like it was running out of gas or something was clogged
E Honda
12-31-2004, 11:37 PM
LOL Whats pretty cheap....These cars are probably one of the hardest to do a head gasket on...Specially if ya got a TT.....Better apply for a loan now.....Ouch..... :eek: :shakehead
rendertrust
01-01-2005, 12:08 AM
hmm well this guy installed a new pendulum in the transmission and it turned out that wasnt what was wrong he said" its ok you dont have to pay me" her did a good 6 hours worth of work for free, he charged 20$ to install new o2 sensors on my moms taurus
this guy would probly charge me 80$ max for something wrong with the motor, im worried more about the part than the labor
besides whats the worst that could happen if i dont fix it, and what caused it anyways, does it have to do with the timing belt
MikeMan
01-01-2005, 03:35 AM
I doubt this problem has anything to do with the timing belt. New head gasket from nissan will probably cost you around $50 USD.
New head will cost you probably $300-$500 USD.
If the head isn't warped too much, you can get it machined, but chances are your uncle couldn't do that himself. Most mechanics need to send it off to a machining shop to get that done.
Probably looking at around $200-$300 USD for that to be done. Keep in mind these prices do not factor labour into them at all and for any of these options, its going to take at least 5-6 hours, probably more if he isn't familiar with the engine.
-Mike
-Mike
Hodo
01-01-2005, 10:51 PM
Putting a headgasket on one of these is hella easier than the Villager I am working on in my shop. Took about 4 hours to get the valve covers off.
E Honda
01-02-2005, 03:44 AM
-Mike
NEW HEAD FOR 500.00 BUX......NO WAY.......I Bet the bare casting will set ya back way more than that. And factory gaskets for what I see wil run ya about 220 dead presidents.
Cylinder Head Gasket Set w/ OE head gaskets
A8010-117216
Cause you gonna need some new valve cover and intake/exhaust gaskets too. And may as well change them plugs while its torn down......Don't fix a blown head gasket and your whole motor will soon suffer damage that can but not limited to. but ruining your shit. And leaving you on the side of the road......Resulting in a Tow bill...And having to call pops in the middle of the night to come get ya stranded ass. Pissing off moms also cause pops woke her up in the middle of the night. The moral of this story is ,,,,,,Don't put off till tomorrow what you can do today. And And I still missed id this car is a TT or not........If it is.......Turbo seals are a must while ya torn down this far. Also a new timing belt......
Just my :2cents:
-Mike
A8010-117216
Just my :2cents:
MikeMan
01-02-2005, 06:18 PM
Ok, maybe I got lost in the conversion rate. Keep in mind however that its a 3cyl head, not a 6cyl head. Big difference in price.
A8010-117216
Again, maybe lost in conversion rate but why do you need both gaskets? We aren't replacing both heads.
I think you overestimate the price of gaskets and underestimate the reusability. If its an NA, there are no major pressure differentials around the gaskets anywhere. I'd never reuse a head gasket but I reuse exhaust, intake gaskets all the time on my NA. If its turbo then yeah you're right though, probably not a good idea to reuse them.
What, $5 each for some NGKs?
eh? You still in english?
Just my :2cents:
Hey, it may also be a good idea to check your period key. It may be malfunctioning.
Just my :2cents:
:p
-Mike
A8010-117216
Just my :2cents:
Just my :2cents:
:p
-Mike
E Honda
01-02-2005, 06:57 PM
Its a twin turbo period key..........................................
rendertrust
01-03-2005, 02:02 AM
my cars a 1990 NA hmm i thought i had it on my profile
rendertrust
01-03-2005, 04:46 PM
my car didnt want to start at church when my dad took it, it was the first time he took it to church and that happened .. hes getting tired of the Z not working like it should .... this is the 2nd time the Z didnt have enough juice to start ... i heard the powersteering leak may cause the alternator to fail.. is this true ?
k3smostwanted
01-03-2005, 05:32 PM
yes, it will leak onto your alternator i remmeber someone saying...look under your hood and see if there is a sticker that says something about a Power Transistor Unit replacement or recall... but yes it sounds ike your alt is failing to keep the battery charged...
1viadrft
01-03-2005, 05:50 PM
crappy...
