Window stuck
brianofbowie
12-31-2004, 09:28 AM
Does anyone have any ideas on how to get a back seat window in a 1995 lebaron convertible to go up and down again? Fortunatly its stuck in the up position but it would be nice if I could figure out a way to put all the windows down for the summer.
Renzy
01-14-2005, 05:16 PM
is it manual or electronic?
brianofbowie
01-19-2005, 09:48 AM
electric.
Renzy
01-20-2005, 02:25 AM
well my friend you have three things to check
#1 The fuse
#2 The switch
#3 The window motor
or could also be off track
let me know the progress
BMUNOZ
04-14-2011, 09:41 PM
This might be super late but mine does the same thing. I took it to a window place and they said I needed a new regulator for it. You're lucky; mine is stuck down so it rains INSIDE of my car. LOL
woodcrafters
07-13-2011, 07:22 PM
I have a 1990 Lebaron convertable that I had the same problem. I was doing a search for a motor on the internet one day, contacting several salvage yards. One of them sent me this response. Remove the window assembly from the car along with the motor. At the end of the motor you will find two small holes, squirt some wd40 or Liquid Wrench into the holes connect the motor to a power source and keep working the motor back and forth if you are in luck the motor may start working again. I tried this and one of the window motors started to work the other I had to replace. Other than removing the window assembly I don't know of any way to get the window up or down.
