Need help dealing with interior condensation!! ASAP!!
terriblenone
12-30-2004, 04:13 PM
I'm wondering how I can prevent the inside of my 89 CRX from fogging up during cold weather here in Edmonton, Alberta.
If I use my heater on the front window defrost setting, every other window in my car, including door windows, fogs up fairly rapidly. Then, often while I'm still driving, and every time I park the car, the condensation freezes, forcing me to use my ice scraper on the INSIDE of my windows before I can see out at all. I've tried switching to the winshield+foot setting, but that causes my winshield to start to fog up.
My heater works great, and all the settings do too (panel, foot, window, A/C) so I need to find the setting that would stop all of this condensation and hassle from happening. Or would this be a case of bad seals somewhere? I've gone around the windows and all seem to be fine, so I'm at a bit of a loss for what to do.
I'd like to get this figured out before my 14 hour trip back to school. Any help is greatly appreciated
Nate
walt0023
12-30-2004, 04:21 PM
go to school in florida :)
]{iwi
12-30-2004, 09:35 PM
do u have ur ac removed?
PhReAzE
12-30-2004, 09:47 PM
could try an antifog tinit on the windows, i got mine done, and they don't fog anymore
terriblenone
12-30-2004, 09:50 PM
{iwi']do u have ur ac removed?
Nope, it is still there and still works.
]{iwi
12-30-2004, 09:59 PM
do u have any leaks by chance?
reson i asked about the ac was i have came in to the same prob. on every one of my hondas after i removed the ac
]{iwi
12-30-2004, 10:01 PM
did u use fog x and did it work good and how long does it last
i have the same problem with my hatch now that it dont have ac
steve-o317
12-30-2004, 10:11 PM
my 89 std has the same problem my defrosters will clear up the windsheild and half of my door windows and my rear defroster will clear up the top half of my rear window. i dont have a/c and i tried the rain-x anti-fog and it didnt seem to work but maybe i put it on wrong. so i would also appreciate any help.
TheSilentChamber
fog x works but there is usually a visable film. The condensation is caused by your defroster/heater more than likely. Your windows get real warm, then when you kill the car the windows get very cold very fast causing condensation on the inside of the windows.
2CrX
12-30-2004, 10:38 PM
If you run the ac while the heat is on it will pull moisture out of the air.
arodg25
12-30-2004, 11:54 PM
i got the same problem. im in rainy b.c. i set the heater to pull from the outside air and set it medium heat. gets a little colder but the fog goes away.
turtlecrxsi
12-31-2004, 09:01 AM
Have y'all tried the little lever on the left side of the column that actuates the air flowing coming from outside or closed not letting outside air in? Not sure if it would make a difference. Also, when you get the defroster to work have you tried the recirculate button to keep any unwanted outside air flow interfering with the inside to maintain constant temp?
