2000 Z-71 Electrical question
232 thumper
12-28-2004, 05:41 PM
Hi All -
I am curious if I can simply swap out my factory fog lights with an aftermarket set, using the same wiring and switch.
Thoughts?
Thanks!
airpanefixr
01-17-2005, 11:36 PM
Shouldn't be a problem. The wires on the stock are a positive and a ground. Just cut them and splice them into the new lights
RMW
01-19-2005, 11:23 PM
check the amp load you blow a fuse or burn up some wire
so first check the fuse for the stock lights and see if it the same .if not the factory wireing is strong enough to handle about 5 to 10 more but to be safe i would run a relay 5 post ford style
