What would I need???
Phat_Si
03-06-2002, 06:25 AM
Besides the correct fuel and spark what would I need to safely run 10-13,14 psi??? What will i need internally and what will this cost me??? When you tell me what i need please include the regular prices!!! thank you! I will be running a d16a6 crx si engine. thx
SleeperTeg
03-06-2002, 08:43 AM
I too would like to know this....
For higher psi is it bottom end, top end or both? Probably forged pistons rather than cast. Dont you usually build up the top end for higher RPMs?
Any info would be great...
90CRXZCSi
03-07-2002, 01:02 AM
Either way you should build up both. For the head it's camshafts, camsprockets, valve springs and the bottom is pistons,rods, sleeves, etc. If you want to safely run up to 14 PSI i would recommend doing both.
