b16 boggs when floored
Sicc Si
12-23-2004, 10:02 PM
my b16 has always bogged when i floor it, i just rebuilt the motor now i have a check engine light & it still boggs when floored.
Does anyone know if it could be a sensor? :screwy:
bambam89lx
12-23-2004, 10:33 PM
well duh....yah!
if you have a Check engine light...it is definitely one of the sensors...
now you have to figure out which one. Look at your ecu and count the blinks to determine which code you are throwing and post here...
well solve the problem for ya...
91civichatch2571
12-25-2004, 10:17 PM
so??
civicunrest
12-26-2004, 12:14 AM
have you checked you fuel filter?my car did the same thing and i replace the whole fuel filter and it seems to be working okay now
Shaguar47
12-26-2004, 01:10 PM
Might be the TPS, since most bogging does associate with that.
H4Bangin
12-28-2004, 12:29 PM
Sicc Si doesn have an led on his ecu, his car isnt wired right to get the codes, we'll try the fuel filter an see if thats it, Anyone know what wires on the ecu to use to get the codes?
amy@af
12-28-2004, 12:39 PM
i say the problem is the driver, not the b16 :screwy:
http://tech2.hybridgarage.com/ecu.php?ecutype=pr3_a
if you have a pr3/pw0 the light should be on the top of the ecu. either of those ecu's is what you should be using for obd-0
H4Bangin
12-29-2004, 10:36 AM
ummm no lol :grinno:
thanks for the info :smooch:
fast2camciv
12-29-2004, 11:46 AM
i agree.
