Cold Start Sputter
Grug
12-23-2004, 01:12 PM
Hey folks! Bought a '03 ZTW last week and I notice that on cold mornings it idles kinda' rough for 10-15 seconds after you start it. Then, it settles into a nice smooth idle. Could this be some kind of choke problem?
Any thoughts!
Cheers and Merry Christmas!
Mustangman25
12-23-2004, 02:38 PM
There's no choke on an fuel injected car :)
It's probably just the car running rough as the computer tries to sort out air fuel ratios with the cold, so in a way, it's a 'choke' issue of the engine trying to run real rich, but not the traditional choke that would be on a carbeurated (sp?) engine. My car does this too when it's cold...it was -10 F the other morning, so I didn't expect much different.
Grug
12-23-2004, 09:24 PM
Ok, so then I shouldn't push the panic button just yet? Is this some kind of problem that the computer sorts through or does it ultimately end up needing some kind of adjustment?
Mustangman25
12-23-2004, 09:38 PM
The computer is just trying to figure out what the best air/fuel mixture is at such a low temperature...that plus the fact that it's cold, and the engine hasn't been run in a while, it's bound to make some noises and shake a little bit as everything settles into place. Unless the shaking and noise don't disappear after startup, I wouldn't worry much about it.
