Speakers in my '02 Xtreme
Booch
12-13-2004, 11:39 PM
Just bought a used '02 Xtreme, and want to upgrade the stereo.
Took off the dash speaker grill, and found 1.5" tweeters mounted on an adapter plate; they look stock, and have what looks like a capacitor wired in front of the speaker (must be a filter, 'cause it sure isn't a crossover!).
The stereo is stock, with only the four speaker outputs.
So, did GM ever offer the seperate mid's and tweet's with a factory filter? Has anyone ever heard of this?
Lastly, if I just splice off the front speaker wires coming out of the head, convert them to RCA's, run the RCA's to a seperate amp, and then wire the two channel amp output back to the two front speaker wires at the head (using the stock crossover or filter or whatever the h*ll it is), how would it sound? I know an aftermarket crossover would be better, but if I use the stock filter, how would it sound?
Any help's appreciated!
BlazerLT
12-14-2004, 03:54 PM
Don't use aftermarket speakers with the stock headunit. Replace everything or replace nothing.
The stock system uses 8ohm speakers and if you replace them with 4 ohm, you will burn out your deck really quick.
chcknugget
12-14-2004, 04:06 PM
Yeah the capacitor is for filtering out sound frequencies. Pretty ghetto, but hey it works nice! It's better than having 4 midrange speakers putting out blah.
BlazerLT
12-14-2004, 04:15 PM
caps are used to filter out the low and lower middle frequencies only.
