93 camry car wobble
t4ia
12-12-2004, 06:41 PM
Hi,
I have a 93 camry which shakes when I drive at around 20 mph. At this slow speed I notice that the steering is shaking and also the body of the car shakes left and right. Could it be bent rim, tire or something else? I took it to a garage and the guy says that it could be axle or drive shaft? Does axle or drive shaft can cause the car body to shake at low speed?
Sl@M C@M
12-16-2004, 12:46 PM
my car was doin the same thing...not too bad of a wobble but steering was shaky....but it came out to be just a bad tire or maybe unbalance in the rim cuz once i got new tires ....the problem was solved ...so check for irregular wear on tires..hope that helps you out...let me know what it was if you fix it.
