LT4 Conversion
poormillionaire2
12-11-2004, 01:07 PM
Is the LT4 Conversion really worth the advertised 425+ hp for my stock 94Z? How much power would I actually get?
http://store.summitracing.com/default.asp?target=partdetail.asp&part=NAL-GMP3287-1
Chevyracincamaro
12-11-2004, 02:14 PM
the couple people on here that i remember saying the did the LT4 conversion were over-joyed with the results. i dont know how much power you would get but everyone says its worth it...
CORE402
12-11-2004, 03:49 PM
What summit says about the product is probably true. I mean you are getting what counts -->HEADS<--, cam, and intake. WOW, but that is a lot of money. Does AFR make heads for the LT1? They might be cheaper then those GM LT4 heads and I am sure they would make better power. $2300 I would expect a 500+hp motor not a mere 425. For my engine I could purchase the Holley systemax kit for an entire grand less then that and acheive the same power rating. That kit includes heads, cam, intake, and some other misc parts.
poormillionaire2
12-11-2004, 08:07 PM
FYI - I found that the AFR heads I found are priced at $2500, just for the heads. http://www.proficientperformance.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=PP&Category_Code=afr_heads_gm_lt-1_street_180_comp_legal
Do you know of any others sites that have the same or similar parts for less?
drumcat
12-11-2004, 08:09 PM
I'm doing the LT-4 conversion to the lt-1 I have lying around...
poormillionaire2
12-11-2004, 08:38 PM
You're gonna have to keep in touch and tell me how it goes. Where did you get the kit from and how much did it cost you? Are you doing the install yourself? Did you get any other upgrades like a heavy duty timing chain or upgraded injectors? Sorry for all the questions, just really curious.
CORE402
12-11-2004, 09:44 PM
Wow stuff for new Chevys are insanely expensive. I dont know what to tell you man. I like LT1s and LT4 and all but man I am sure glad I have my good old fasioned Gen I SBC. I can tell you other head manufacturers but I am no LT1 expert.
drumcat
12-11-2004, 10:03 PM
I will most likely order it on monday or tuesday, I saw the conversion kit in the last Summit catalog. Yes, my dad and I will install it our selves
poormillionaire2
12-12-2004, 08:52 PM
Are you gonna put your car on the dyno before and after you complete the install to see how much power it was actually worth?
KaotiKCamaro5
12-12-2004, 10:45 PM
im thinking about having it done if i get the Trans Am this spring.. i just wanna be able to hang with the big dogs.. (formula and hypsi) i'll likely get the kit from Summit as well..
poormillionaire2
12-13-2004, 12:00 PM
I'm too lazy to do a search but I think that summit is one of only a few places that have the kit. Isn't the LT4 only offered by GM?
KaotiKCamaro5
12-13-2004, 12:59 PM
as far as i know.. but you can likely pick it up from someone else.. i've seen people selling the parts on ebay.. however i have never seen the full kits on ebay..
drumcat
12-13-2004, 02:48 PM
Yeah I'll try and find a place around here where they can test it at the crank because this engine isn't going into the RS I have now
SMOKEY818
12-13-2004, 04:35 PM
i've heard that the lt4 conversion was overrated & it would be better to just supercharge your maro and you'd end up happier
Chevyracincamaro
12-13-2004, 06:03 PM
i think that the conversion would be more economical than forced induction. he wont have to build up the rotating assembly with the conversion. plus, if you do the conversion and later on supercharge, then you would really see results...
poormillionaire2
12-13-2004, 08:32 PM
An LT4 plus a supercharger...be putting out some serious ponies...
Chevyracincamaro
12-13-2004, 08:33 PM
the only way to fly...
poormillionaire2
12-13-2004, 08:47 PM
Now a circular debate LT4<------>Supercharger...hmmmmm
Maybe I'll just get a blown 427. Ha.
KaotiKCamaro5
12-14-2004, 12:07 AM
heres the big thing with the LT4 conversion.. the cost.. its relatively cheap compared to forced induction.. a supercharger is gonna run over 3000.. closer to 3500, where as the conversion kit is only 2300 from summit.. im pretty sure tacomaman has the LT4 conversion on his 94 Z28 i think it is.. i would send him a PM and see how he feels on the subject.
drvngstorm05
12-14-2004, 12:39 AM
i just checked out that kit, its pretty impressive. although i already put on everything in that kit on my lt1 cept for heads and intake. i have the "hot" cam (which isn't highway legal :evillol: ) roller rockers and stuff. plus i have put on more tense valve springs and a heavy duty timing set
poormillionaire2
12-14-2004, 01:08 PM
If I were to have the kit professionally installed and tuned, how much should that run me? Just to get some idea of how much more to add on to the actual kit.
tacoma man.
12-14-2004, 02:44 PM
how about doing the lt4 conversion and supercharging it..... :evillol:
but it would cost you 6k+ plus you had better build up your stock tranny,
unless your car is a t-56.
Chevyracincamaro
12-14-2004, 02:45 PM
thats a good question. it will prolly cost you a load if you take it to a shop. if you have like a speed shop around you i would think that might be a little cheapier, but its hard to say. one thing to make sure is see if the shop will take the engine out or do the work with the engine installed. that will make a huge difference in labor cost...
poormillionaire2
12-14-2004, 10:12 PM
Hey thanks, I never would of thought about someone taking the engine out or not. That would cost more. I'll make sure to bring that up when asking around for costs and stuff.
kmdracer
12-14-2004, 10:28 PM
I think that @ $2,000 for 400-425 hp with parts that are guaranteed to work together is a pretty good deal, considering what you are getting. Here's a couple of other prices to compare with. I know summit offers fre shipping, but not sure about the others.
http://www.gmpartsdirect.com/results.cfm?singlepart=1&partnumber=pk12550630
http://www.sdpc2000.com/search.asp?searchterm=lt4+conversion+kit&doQuery=1
Hope this help some.
Kevin
