driveshaft question
Chevyracincamaro
12-10-2004, 11:28 PM
im lookin at gettin an aluminum one-piece in the next couple months and i found the one that i want for cheap but it says i need to supply my own transmission yoke. how difficult is it for me to pull the old yoke and put it on the new shaft, or would it be better to take it to a shaft shop and let a pro do it?
89IROC&RS
12-11-2004, 03:05 PM
should be a no brainer, you can definatly do it yourself.
Chevyracincamaro
12-12-2004, 08:27 PM
thank you kindly...
69ralleygreen
12-12-2004, 10:22 PM
thank you kindly...
That question depends if your car is all stock or a fast hod rod, Stock car go for it ,ive done mine on the ground , But if you have al little coin and a hot rod, I would drop it off at a shop have it done and balanced. It makes a big differece since its not from the car...mike
Chevyracincamaro
12-12-2004, 10:45 PM
yeah, she's mostly stock. i might get that one or get the lingenfelter shaft, havent decided yet so i might not have to worry about it...
SMOKEY818
12-13-2004, 04:25 PM
how much is the lingenfelter drive shaft?
LT1MAN
12-16-2004, 02:52 PM
ls1 shafts are good i heard...aluminum anyway, a lot lighter than the boat anchor in mine
