'97 Stereo Installation Question
buyside2000
12-09-2004, 10:15 AM
I was wondering if someone could tell me if you have to unscrew anything before removing the first piece of the console? I know that you have to start with the piece closest to the armrest that goes over the emergency brake, but I can't tell if anything needs to be unscrewed before popping that piece out. Thank you!
blazzingbrandon
12-09-2004, 04:39 PM
First: Pull the handbrake up, then just take off that piece. It will not completely come of because there are wires attached. Next, put the shifter in L and unscrew the 4WD knob, then take the next peice out(completley). There are 4 screws where the AC/HEAT/adjustment thing is. There are good links on the internet on how to take is out, here is one, but there are better ones for free, also search this forum, it has been discussed before. http://www.carstereoremoval.com/htm/stereoremovalToyota4Runner96_98P.htm
buyside2000
12-10-2004, 02:09 PM
Thanks for answering- I had looked online, but couldn't find anything for free. Forgive my ignorance- what is "L"? (Put the shifter in L)? I started to pull that first piece off last night but couldn't get enough leverage to pop it out. Glad I didn't push it too much because I didn't have the brake up! Thanks again for your help!
Tomsriv
12-12-2004, 11:39 PM
"L" is low gear. Some manufactures use "D,2,1" others use "D,L" or "D,2,L". In other words, pull the stick all the way back.
buyside2000
12-13-2004, 12:49 PM
:S
I feel dumb- figured that out when I got in the car. Thank you so much for your help. I was able to pop the parts right out and then back in again. Thanks again!
