won't start
mike3028
12-06-2004, 08:24 AM
i have a 92 camry that won't start. a mechanic changed the distributor and it ran fine for about 30 mins. and then i let sit for a couple of days and now it won't crank back up. anyone have any suggestions on this would be greatly appreciated. thanks
Brian R.
12-06-2004, 08:58 AM
What happens when you turn the key?
mike3028
12-06-2004, 11:29 AM
the motor turns over good but will not crank
Brian R.
12-06-2004, 12:52 PM
Sorry, I still am unclear on what happens. The engine is turned by the starter, but it doesn't start running? Is that what happens?
mike3028
12-06-2004, 01:41 PM
yes, that's what happens. everything works fine except the car will not start
Brian R.
12-06-2004, 02:57 PM
Can you check to see if you have spark and fuel? You need both.
maxachico
12-08-2004, 04:49 PM
I have roughly the same problem. I have a 93 Camry 4cyl. I JUST replaced my distributor today with a NEW (not REMAN) part. I had replaced the distributor before, about 6 months ago, but it was a REMAN. It crapped out last week, so I got the REAL-DEAL Toyota part. I put it in and let the motor idle for about 10 minutes. About 2 hours later, I went to the store about 10 miles away. As soon as I put the car in "Park" it died!!! It will still turn over and run, but if I don't hold the gas pedal it will die. I drove it home using the gas and brake simultaneously to keep it from dying at idle speed!!! NOW WHAT DO I DO???!!! :disappoin
