starting problems
tdenny
12-05-2004, 09:25 PM
i have a 1993 s-10 pu 2whd with a 2.5L engine. Reacently i developed a cold starting problem. i have changed the map sensor, intake temp sensor, plugs wires to try to correct this problem. No codes came up when i scaned it and it runs fine once it has started. good spark and fuel. timing is good. i really don't know what to check next, so if anyone has any answers let me know.
rwgreen
12-06-2004, 03:13 AM
Does the engine try to turn over, or do you get nothing at all when you turn the key?
Mikado14
12-06-2004, 09:38 AM
Check your fuel pressure.
tdenny
12-06-2004, 05:45 PM
engine turns over fine, plugs and wires are new as of yesterday, and it has lots of fuel pressure, only seems to not start on rainy days.
Mikado14
12-07-2004, 09:46 AM
If it's fine, what is the pressure that you read?
Also, if you get it started, spray some windex or even just a fine mist of water on the coil and see if it arcs.
tdenny
12-07-2004, 06:56 PM
the problem seems to be fixed, I found a burnt wire with cover melted, when engine was turned over wire ground out to the block causing the intake temp sensor to read incorrectly. thanks for the help i may need more in the future
