Headlight Interchange
OldBeau
12-05-2004, 05:54 PM
Does anyone know if the headlight units from the 03/04 LS will fit in the 2000 LS?, I have been told they have much better optics and I may need to change mine out again due to non-stop fogging and moisture build up, any guidance is appreciated.
Quik_LS
12-05-2004, 08:21 PM
well - sort if.
you can put 03-04 headlamps into a 00-02 by also changing the front cross-member that the lights bolts to (the one the runs between the fender and behind the bumper).
if your lamps are fogging it's an easy fix. take them out, put them in the oven at 215 for 15mins - it loosens up the glue - press all around the seal, then re-cock it using RTV.
I've had my lamps apart (using the same procedure) several times to remove the amber corner lens and add 'angle eyes' rings.
