twin turbo
TerryJoe
03-01-2002, 10:28 AM
is it posible to put twin turbo on a stock 94 accord engine?
or should i do a engine swap then the turbo?
thx for the info.
thx terry thornbrugh
buh_buh
03-01-2002, 12:52 PM
I don't even know if a TT is possible with a Honda.... even with a swap you decide to do (unless you can somehow swap a FC or FD motor into your Accord)
cybercrx00
03-01-2002, 02:39 PM
I am almost positives there is or was a twin turbo kit out for the integras, can't see it being all that much of an advantage....more of having something exotic on your car.
Jarflow
03-01-2002, 03:02 PM
ive seen a twin turbo integra super charger and turbo charger were stacked
there was alot of rigging in that car but it was pretty amazing
swissturbo
03-01-2002, 03:58 PM
here in switzerland is a tuner who build a twinturbo in a crx del sol.
he combinated a supercharger and a turbo.
but the car still have problems with the ignition.:smoker:
drift
03-01-2002, 04:44 PM
unrealistic for the acoord. the engine doesnt have enough output to drive both turbos efficently.
besides, with only a small amount of boost, the F22 is known to pop.
sohcvtecrx
03-02-2002, 10:08 AM
the apex drag integra is running twin turbos, and its in the 8s, however they did say it probably be more efficient with a single turbo setup.
jOYRiDe
03-02-2002, 10:27 AM
ding ding 100 points for u!!
why go thru all the trouble of having a TT setup when u can wack on a larger single turbo and run the same times?
VTECseoul
03-02-2002, 10:17 PM
what 1/2 of ya'll talking about is called TwinChargers - SuperCharger & Turbo setup. the Meguiar's Integra is made like this. the theory is that the S/C has instant boost for takeoff & then the turbo takes over after full boost. how they control the turbo from not backbuilding on the S/C, i dunno; but it's a show car, not a racer.
but a twinturbo setup on Inline 4s is ridiculous. TTs are best for V8s & 6 cyls, yet SingleTurbos on Grand Nationals/TAs & MKIV Supras converted to ST can make 2.0 bars (almost 20lbs) of boost.
TerryJoe
03-02-2002, 11:18 PM
i am very grateful to all the help thats has been given.
can u tell me were to find a larger single turbo?
and what all would i need to add on the engine for best performance with the turbo.
thx
terry thornburgh
jOYRiDe
03-03-2002, 05:57 AM
you'll needs lots of aftermarket goodies to make your car go fast
speak to drift, he has a turbo lude in the works and i think he just opened up a shop
Brice
03-03-2002, 09:20 PM
Dude, just go with a single turbo
ShockJon
03-04-2002, 12:46 AM
I heard that the TT work off each other in two stages one does the first half and the other does the second half..... Thats the way I unsderstood it!!! I kinda makes more since that way than having two trying to blow into the same pipe!!! :rolleyes: That way it eliminates some lag too...
Self
03-04-2002, 05:22 AM
That's called a Sequential Turbo setup. One takes care of boost at low RPMs, the other handles high-RPM boost. Most V6's and V8's don't use sequential turbo's, b/c there's two "sides" of pipes to blow boost in(hard to describe, but I think you know what I mean if you've seen a v6 or v8). Most I6's and I4 twin turbo setup's use sequential turbo's b/c like he said, it's hard to have two turbo's blowing into the same pipe!
mellowboy
03-04-2002, 11:45 AM
..exactly! IF it was an inline 6 (supra) u can use one turbo instead of 2. Because it doesn't go simutaneously liek the v6 and v8's or other whatever. Some ppl like to put a big fat single turbo on a supra cause i guess its much better that way? Well i remember that this one magazine..i think it was SCC? They had a project building up a v6 accord twin turbo (please someone correct me if i'm wrong) and the project failed. I just don't that much about it but all i can say that it failed from what i heard. Just throw a single turbo and u'll be fine...or swap an h22 and then throw a turbo!!:)
Brice
03-04-2002, 04:20 PM
Dude, it's easier, more economical and efficient to just go with a single turbo putting out all the power. Don't waste your time or money doing a
TT conversion to a Honda! :rolleyes:
SleeperCivic
03-04-2002, 08:23 PM
Boost, boost, boost,
All day long,
Gonna boost my turbo while I sing this song,
Gonna spool it up and hear it scream,
Then drop the clutch on my D16....
Hope you guys enjoyed that one.
MARKUSIUDIUS
03-06-2002, 04:40 AM
F22 are piss poor engines unless you are going give it some huge boost (15psi) and change the internals I wouldnt worry about it.
Buy a current Accord 3lt V6 vtec with 200hp and plenty of room for a turbo setup. I would say its good for 300+hp with not to much trouble, thats my next setup. But more like 400hp:flash:
But I will just wait for the facelift just incase.
