1988 Suburban - Rear Window won't close
Mdguy_20878
12-05-2004, 08:18 AM
The electrically operated rear window on my 88 suburban won't close. Apparently it is trying as the heater fan slows down and the ammeter moves, when I try to open the window. Any tips?
immonacan
03-19-2005, 10:43 AM
my '88 had the same problem, but would finally close slowly after several trys. I took apart the panal cover on the tailgate to expose the motor, regulator and window tracks. I wiped off all the old dryed glops of grease, and re-greased the window regulator arm pivit points. I sprayed the window tracks with a synthetic grease. Works much better now.
84fiero123
03-20-2005, 06:27 PM
do the lube avery where it moves
wlfowler29
03-21-2005, 12:42 PM
Make sure the tailgate is latching on both sides as well. There are contact switches that won't let you operate the window unless the gate is closed completely. I have seen them where one side does not latch properly.
