1190 Lumina 2.5L No Spark or fuel to intake
Johnfiac
12-04-2004, 07:36 PM
I have a 1990 Lumina 2.5 liter and it wont start, i put a new ignition module and crank sensor on it and still no sign of starting, the fuel pump turns on so i cant figure whats wrong. Please Help!!!!
cadgear
12-04-2004, 10:04 PM
If the engine does not even turn over, check the starter and cables going to it. Check all fuses and relays as well.
GMMerlin
12-05-2004, 07:46 AM
Is this a spins and no start or a engine does not turn over issue?
tblake
12-05-2004, 09:45 PM
if it cranks, and there is no spark, and no fuel, sounds to me like an ecm problem
Natae
01-10-2005, 01:13 PM
Hello, IM reading this about your Lumina and I see I have the same problem right now with my 92. It was running ok as of Saturday, then brakes went out on me, Hubby fixed brakes,( it had rusted out on right rear) now it wont start no matter what he does. Did you figure yours out for sure if so post an answer here maybe? Thanks Nat
