How about a 92 Laser RS T AWD for $2000.00
Automobile Maniac
12-01-2004, 11:05 PM
You DSMer's have the biggest forum I have ever seen, you guy's really know your stuff so I figured I ask about a DSM I was thinking about buying, it's $2000.00.
What do you think about a 1992 Laser RS Turbo AWD blk on blk manual.
-They say it has a '91 Eclipse GSX 6 bolt engine
-4 bolt rear axel
-145,xxx miles on the body and 87,xxx miles on the engine.
-Timing belt was changed 4500 miles ago
-free mods (hacked Mass Airflow Sensor, BCS removed, etc.)
-pacesetter tubular headers (not installed)
-dejon 3" intake
-k&n filter
-autometer mech boost gauge
-dual piller pod
-front and rear strut bars
-k&n breather filter
-ngk wires
-ngk plugs (-1 degree colder)
-custom manual boost controller (set to 12 psi)
Paint good, interior good
List of small problems: Power mirrors need new switch. Cruise Control has been disabled. Blower motor (heat/ac) burnt out during use with previous owner.
Engine runs great. Standard DSM upkeep will be needed. This means that the transmission will need a good flush and the shifter may need some new bushings in the next year or so. I removed the fog lights on the front bumper so that more air would be sent to the intercooler. It runs much smoother this way. This car is a great deal.
Thats what I am up against- Good Deal???????
THANK YOU FOR ANY REPLIES!!!!!!
-4 bolt rear axel
-dejon 3" intake
-k&n filter
-dual piller pod
-ngk wires
Urban_Squrill
12-01-2004, 11:26 PM
Thats a good deal! Wish i could find one like that around here(cant even find a 1g aWD 5 speed).
1stGenRocks
12-02-2004, 12:06 AM
sounds like it could be a deal. iw ould try to talk him down some though since its probably been raced. any car with mods i would check out pretty thourghly to make sure they are done right. if you check vfaq.com you can see the right way to install all of the stuff that car has. the next thing you should do if you buy it is an exhaust
