90 Accord Power Window Problem
icyblue33
12-01-2004, 10:14 AM
I have a 90 Honda Accord and the Driver side window will not go down. All the other windows work properly. I haven't tried to force it down to see if its stuck or anything, but it was working up until a few days ago and now it just wont do anything. I checked the fuse and it is ok, so where do I go from here?
Ehscrewdude
12-01-2004, 03:36 PM
Unless you want to take it to a dealer, take off the door panel and check the wiring/power to the window. After that, maybe replace the motor, or make sure you didn't wear out the gear that raises and lowers the window...
Igovert500
12-01-2004, 04:21 PM
Another problem to check when you take off the door panel...under the track that holds the glass...there is a metal thing in the shape of a folded X. This is what raises and lowers the track...mine got bent once and it would get stuck on itself and not be able to move...since it couldn't unfold the window wouldn't go up or down. Check that for clearance issues.
