sc belt replacement
lovatbr
11-29-2004, 12:31 PM
there is not enough play to slide new SC belt on tension pulley. any suggestions? factory standard pulley and replacement belt.
GTPWarrior
11-30-2004, 07:53 AM
use a ratchet and put it on the bolt of the tensioner you may need to put the belt around the pulley the the SC last. If this is too tight then check the play of your tensioner it may need to be changed.
stlwagon
11-30-2004, 08:00 AM
Agree. Try putting the belt on just partially over the s/c pulley and then over the belt tensioner. You should then be able to slide the belt on the rest of the way.
