E30 wheel help
Tougeman
11-28-2004, 09:59 PM
What are the widest wheel/tire combinations htat will fit on a E30 without rubbing?
I am looking at some 16 or 17x8 all round and wondering whats a good offset and tire size
catman3
11-28-2004, 10:32 PM
Hi,
Usually, there is the wheel and tyre information label stuck at the chassis when you opened the door. You can change larger diameter but thicker height. For example, you can use 205/50/R17, if you use 225, you should use 225/45/R17. Check that. In some model, if you use wider wheel, there are some racing spacer added to off-set the wheel. But you should check with the local government rule if it is illegal??
Celsdogg
11-29-2004, 10:11 AM
im not so sure about tires and rims, but i am sure someone at the tirerack.com can help you. . .
