need help on programming remote for 95 camaro z28
c2cyo
11-27-2004, 08:25 PM
i just bought a keyless remote on ebay..i thought the program was included but i read wrong :p...can anyone help me program my remote please...please..thank you =]
c2cyo
11-28-2004, 01:18 PM
anyone know wehre i can program it? any links? i tried doin a google search but nothin...
cuda_dude
11-28-2004, 05:23 PM
1995 and earlier Keyless Entry Programming
The Keyless Entry Receiver is capable of accepting Vehicle Access Code (VAC) programming from any two random Transmitters. One or two Transmitters can be programmed. When two Transmitters are programmed, they must be programmed during the same program sequence, one after the other but not simultaneously. The Transmitter is manufactured with a permanent VAC combination (one of over 4 billion combinations) that cannot be changed for the life of the Transmitter. The Receiver can only be programmed by the Transmitter when it is powered at the Battery input at connector C2 terminal "F" and the program input line is grounded to connector C1 terminal "A".
Programming procedure:
Ground the program input line by connecting a fused jumper at the Data Link Connector (DLC) from terminal "G" to terminal "A" (note: use terminal G and A for pre '95 12 pin DLC. A is the top right pin and G is the bottom left. Use terminals 4 and 8 for the '95 16 pin DLC. The 16 pin DLC connector is numbered top left (1) to top right (8) and bottom left (9) to bottom right (16) ). The Receiver will cycle the Door Lock Actuators within one to three seconds to acknowledge that the Receiver is in the "PROGRAM" mode.
Press any button on the Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Press any button on the second Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Remove the fused jumper from the DLC and verify system operation using all three Transmitter buttons.
Important
Always program both Transmitters when replacing a lost or damaged Transmitter. The first Transmitter Code programmed will always be in both memories until a second Transmitter is programmed within the same sequence.
The Keyless Entry System will not be operational if the program input line is left grounded.
Program only one vehicle Keyless Entry System at a time. If multiple vehicles are being programmed in close proximity simultaneously, it is possible that the same Transmitter could be trained to more than one Receiver.
c2cyo
11-28-2004, 07:22 PM
its a little hard...but i can give it a try...
anyone else have other ways?
cuda_dude
11-28-2004, 08:26 PM
you can use a paperclip as a fuse jumper, one end in the #4 terminal and the other end in the #8 terminal
c2cyo
11-30-2004, 05:03 PM
well got my remote workin....i used a paper clip.. first i put in number 4 then number 8 but i miss the firstt time and hit another one and saw a spark...hope is nothink serious or hope it didnt burn out anythin..
thanks for your help
