Please help with BOV
MetalTwitch
11-24-2004, 07:28 PM
ok so i know that the stock bypass valve connects to the intake and intercooler hoses and there is a third hose. i bought a universal hks sqv and i was wondering what do i have to do to the intake hose? does it need a breather? the bov that i got doesn't have a space for that third hose. Please help.
Hotshot8792
11-24-2004, 10:20 PM
ok, you go an open blow off valve, first thing you will probably need is the adapter for the 3/S since you bought the universal blow off valve. You will then hook up the blow off valve to the y-pipe, and will hook the pressure vacuum hose that connects to the intake manifold to the nipple made for a small vacuum hose. Then, you just plug up the intake T pipe, just go to home depot and go to the plumbing department and find something to plug it up, and clamp it down with a hose clamp, and you should be all good.
MetalTwitch
11-26-2004, 08:53 PM
Hey hotshot thanks for the help i kinda figured it out but thanks anyways. hope to chat with you about 3ks sometime. if you have aim just im me.
