1997 t-bird v6 check engine lt on misfiring...help!!
shelli76
11-23-2004, 09:16 PM
1997 T-bird V6 Just got car smogged check engine lite been on since, car mis fires very badly to the point that if I'm on the freeway I have to put the car in neutral and turn the key off, coast for a second, then restart it...Also runs really rough...Can anyone help me?
8ate8
12-06-2004, 09:12 PM
did you get the codes read?
shelli76
12-07-2004, 11:41 AM
No, unfortunately.........and the car is getting worse..With the situation I'm in I'm really relying on my bird to get me around, its all I have. I did however find out that it might be a problem with a spark plug...sure enough upon checking one of them was cracked, so I replaced them all...worked alright and the check engine light went off for about 2 hours I would say....then it started in all over again. Any advice??? Thanks in advance!
Shelli
Shelli
thunderbird muscle
12-07-2004, 04:43 PM
You need to have the codes scanned. You can go to a parts store like advance/autozone and they will do it for you.
8ate8
12-07-2004, 07:22 PM
Yea, the check engine light comes on for a reason. You can't just look at the light and then ask for solutions to your problem. Get the codes read, and then perhaps we can help you a bit more.
