My Explorer is haunted
Gideonfrost
11-23-2004, 11:53 AM
First I'd like to thank you ahead of time for any help anyone can give me. I recently got a 1995 Explorer (eddie bauer edition if that helps any) And the Battery kept dying on me, I even bought a brand new one and it still died after only a few days. Well one night I got home from work and the headlights were just on. I had driven it a bit before I went to work so I thought maybe I was just dumb and left the headlights on. But the switch was turned to off. Eventually I put the key in the ignition and turn it then turn it off and the lights go off. So I figured it was maybe the alarm system and deactivated the alarm. So I turn it off and get the battery (the new one) charged up and put it back in. So this time after I drive it I don't turn the alarm on. And the same thing happens. So I'm just totally lost I can't figure out a reason for this to be happening. If anyone has any ideas I'd really appreciate hearing them. Thanks very much.
busa_4
11-23-2004, 03:01 PM
does it have auto lights? aftermarket alarm?
Gideonfrost
11-23-2004, 05:59 PM
It doesn't have day time running lamps if that's what you mean and I'm pretty sure that the alarm is stock, I don't have a remote either for it it just activates when I lock all the doors and deactivates when I unlock it. Also it's done it when the alarm was disabled too. I thought for a while that someone elses remote might have been activating it though, because there is another explorer in my parking lot. I hope this answers your questions. And thanks for any help.
Valdez
11-23-2004, 07:04 PM
Hate to ask, but have the obvious things been checked.........altenator output, dirty cables, etc....??
ponchonutty
11-23-2004, 07:47 PM
sounds like either the autolamps or switch is bad.
Gideonfrost
11-23-2004, 10:36 PM
Okay I've got somewhat of an update here. I found out that the Automatic Antenna motor was running nonstop, so I pulled the fuse for that. Thinking that maybe that since I hadn't been driving it much this was running the battery down and the headlights were just a separate problem. Then I find out that there is a plug that was installed for boat hitches and found a bare wire in that line so I pulled the fuse for that. Also I believe it has auto lamps and I'm trying to figure those out right now, reading the manual. But I'm 99% certain the lights came on several hours after I left the vehicle after seeing that they were off. So they're turning back on somehow I guess.
Also Valxdez we pulled the positive terminal off of the battery while it was running and it didn't die so the alternator is giving a charge as I understand it. Please correct me if I'm wrong there Also the cables look very clean to me. I hope that covers everything for now. I'll be sure and post an update in case you're curious. Thanks again.
busa_4
11-24-2004, 07:35 AM
gideonfrost, never pull the battery cables off a fuel injected car when it is running. there is a chance you can spike the ecm. when you do that you are running the alternator at its peak voltage which is around 16-18volts and if there is a spike in voltage when you remove the cable you could easily exceed that 16-18 volts and of course no computer in the car would survive. i would start looking at your auto lights. you must have auto lights because a standard headlight switch when it fails will no way turn the lights on manually. when a mechanical headlight switch fails the lights dont turn on. look for the auto light relay/control module in the relay carrier or fuse box. it could be under the dash or in the engine compartment.
Gideonfrost
11-26-2004, 07:58 PM
Whoops, well I think I got lucky this time cause the car still runs fine, could the spike have caused the lights to act up maybe? I still haven't looked at the auto lamps yet. I've been really busy with thanksgiving and all that crap. Hopefully this week sometime I'll get a chance to look, before it gets too cold. Heh.
Gideonfrost
12-09-2004, 07:28 PM
Okay I'm just posting this for closure I guess. I've disconnected the Auto lamp terminal or whatever and everything seems to be working fine. Once again thank you guys for all your help.
