Leak
superman0604
11-21-2004, 07:48 PM
When ever it rains hard I get water that leaks in to my trunk. Not sure where it is coming in. Is this a common problem or is there just a whole somewhere? It is not leaking in the top because the carpet covering the trunk does not get wet.
Igovert500
11-21-2004, 09:55 PM
I'm betting it is your tail lights...get some silicone sealant and reseal them.
If it isn't this...although I really think it is...check your wheelwells for rust. It maybe coming in there.
superman0604
11-21-2004, 10:09 PM
I will try that. There is no rust in the wheelwells.
Backstop
12-09-2004, 12:53 AM
I have the same problem with my 91 LS. There is not a speck of rust and the car has mostly been sitting but collects an obscene amount of water around the spare. If I park on an incline it drains out as though someone has drilled a hole just for that!
I have only had the car for less than 2 weeks. I recently got some great condition tail lights off of ebay for only $40.00 and am getting ready to put them in. I am going to pay extra close attention to any gaps and the whole assembly will be getting silicone. Will keep you posted on my success.
TreStringz
12-09-2004, 12:57 AM
Check the hose that runs from the sunroof to the trunk. This hose takes the water and moves it from the sunroof area down and out the wheelwell.
whtteg
12-09-2004, 08:34 AM
Also check the gaskets that are behind the tail lights.
