Arrrgh.............just Drive Already Damit!!!!!
jhmcrx
11-20-2004, 08:18 PM
ever since i swaped my motor, my car has been driving like crap first it had a pinging noise from the valve cover so i added an additive (CD2) from my local auto part store and stoped that. now my exhaust is making pinging/clunking noise and the whole exhaust is vabrating like crazy! and the performance really lags in 1st gear it clunks pops and barly accelerates, so i put a peice of paper to my tail pipe and it sucks it in then blows it out really fast :confused: doesnt that mean theres maybe somthing wrong with my timming or valves?
(yes i bought a d15b SOHC Vtec motor a while back :biggrin: BUT
my mom didnt know that if i put it in my 88 car it never will be able
to pass f@8%IN LAME #&$ SMOG check and SUPPOSEDLY if a cop stops me he will take MY CAR AWAY!?!? thats what my moms socalled mechanic friend told her, and since i was using his spot/tools i didnt have any authority to put that motor in :crying: so i had to go back to makoto motors and exchange it, now im stuck with this "JDM d15b" motor that was carbuerated but switched back to dpfi for
now :headshake: so all that trouble and time for pretty much the same performance as before :banghead:
quiXilver
11-20-2004, 08:45 PM
i would say get a timing light on that beast
sivic02
11-20-2004, 08:54 PM
k20a swap time! lol thats my answer to everyones motor problems.
honda_luvr_2000
11-21-2004, 01:18 AM
sounds like u might have u'r cam-to-crank timing off, if it sucks in on the exhuast then blows out. do that test on the intake side too and see if u get the same result. if u do, then that's definitely u'r problem. a timing light will tell u if u'r ignition timing is off base w/ the flywheel. but it won't tell u if the cam is off time w/ the flywheel, since u can adjust the ignition timing indepentantly of the cam. if u changed the timing belt, or it was changed before u got it, then i'd double check that to see if that's the case. it could be off a tooth or two and that has been the problem of someone else here in these forums
!M!}[
11-21-2004, 01:53 AM
^^^that may be something to check
revhalzoo
11-21-2004, 06:01 AM
timing was off, you bent your valves, take the head off and repair or replace as necessary, at best youll need some valves at worst you need a new head. sounds like you broke a valve OFF so you are probobly fucked. get a ZC.
