Idle Problems No Check Engine Or Vacume Leaks.
clownsV8's
11-18-2004, 12:59 PM
OK IVE HAD MY SWAP IN MY 99 HATCHBACK FOR A WHILE NOW AND IT KEEPS ON DOING THE SAME THING JUST NEVER FIXED IT. HERE'S MY SET UP:
*SIR BLOCK OUT OF A 94 AUTOMATIC WITH 33K
*GSR HEAD PORTED
*SKUNK 2 INTAKE MANIFOLD
*TYPE R VALVES
*CROWER TITANIOM RETAINERS
*SKUNK 2 DUAL VALVE SPRINGS
*OBD1 INTEGRA THROTTLE BODY
**HAVE TODA SPEC C CAMS BUT NEVER PUT THEM IN RIGHT NOW RUNNING STOCK GSR'S(SELLING THE TODAS THOUGH ASKING 900 BRAND NEW IN ORIGINAL BOX WITH SPEC SHEET
*HEAD IS MILLED TO RAIS COMPRESSION FROM I THINK 10.4:1(SIR STOCK) TO 11.5(SUPPOSEBLY)
*TYPE R HEADER JDM(NEED THE EXHAUST DONUT IF ANY ONE HAS AN EXTRA ONE jdM
*THERMAL EXHAUST PIPE WITH APEXI MUFFLER
*MSD SCI WITH REV LIMITER AND EXTERNAL COIL)
*c&r RADIATER
*JUN fLY WHEEL
*ACT STAGE 3 CLUTCH
OK THATS WHAT MY ENGINE SETUP IS NOW THE PROBLEM IS THAT WHEN I FIRST TURN IT ON IT REVS AT 3000 RPM'S THEN DROPS BACK AMD FORTH TO 1500 THEN SETTLES AT AROUND 2100 HELLA HIGH, MY STOCK TACH IS OFF BY 200 RPMS. I HAVE NO VACUME LEAK AND NO CHECK ENGINE. i WAS TOLD BY A FRIEND THAT IT MIGHT BE THE IDLE CONTROL WAS VALVE ON THE GSR OBD1 THROTTLE BODY, AND SOME ONE ELSE TOLD ME IT COULD BE THE VALVE BEHIND THE INTAKE MANIFOLD WICH IS ALSO THE IDLE CONTROL VALVE. IF YOU MIGHT KNOW WHAT IT IS CAN YOU PLEASE LET ME KNOW, I DONT HAVE HELLA MONEY RIGHT NOW SO I NEED TO NARROW THE PROBLEM DOWN THANKS ALOT. IF THIS QUESTION HAS ALREADY BEEN ANSWERED I COULDN'T FIND IT (COULD BE CAUSE IM NEW TO THIS MESSAGE BOARD)
*GSR HEAD PORTED
*TYPE R VALVES
*c&r RADIATER
*JUN fLY WHEEL
*ACT STAGE 3 CLUTCH
civickiller
11-18-2004, 07:43 PM
ever try and adjust the idle and see what it does ?
