95 blazer brake problem
jcarter5
11-17-2004, 09:14 PM
Have a wierd brake problem and hoping someone can help. Sometimes, but not always, when I apply the brakes, it feels like the brakes don't engage well and when I apply more pressure the brakes suddenly grab. Pedal feels like there is a rachet-type effect. Thought one of the front calipers was sticking. Replaced both front calipers and pads and problem still exists. Also replaced brake fluid and bled all 4 wheels and there is no difference. Tends to occur after truck is driven for a while and warms up. Any help is appreciated. Thanks.
wolfox
11-17-2004, 10:20 PM
Hopefully when you performed the swap, you gave everything a good wash of brake cleaner when done. Any contaminants, like caliper grease, brake fluid - your fingerprints even; may cause what you are describing. Check the caliper pots too for any signs of leakage, and mind fluid levels...flush and air-dry all exposed parts you can get with a quality brake cleaner and see if it helps. Dry any rubber boots and seals you splash with cleaner with a rag quickly. Some flushing solvents will rot rubber.
BlazerLT
11-18-2004, 02:15 AM
Check to see if the brake fluid is up to the proper level and check if there is any vacuum leaks from the brake booster.
