96 GMC Jimmy P0108
Tstown
11-16-2004, 07:42 PM
Need help. Recently received a code of p0108 - Map sensor high input voltage. The vehicle does not shift into passing gear when throttle is mashed and receiving major spark knock.
So far we have:
- checked timing set at -1 degrees
- installed new map sensor
- Recently have had the transmission rebuilt, shift problemn may not be related.
Any ideas where to check next? What would give the map sensor a high voltage input error.
BlazerLT
11-18-2004, 11:11 PM
So far we have:
Did the check engine light come back on?
Tstown
11-20-2004, 05:15 AM
Yes, the check engine light comes back. Same code. Any ideas at all?
BlazerLT
11-20-2004, 01:59 PM
With MAP sensor replaced, I would have to think you might have a Computer problem.
The shifting thing is not related, but why haven't you taken it back to the guys that rebuilt it?
Tstown
11-20-2004, 05:29 PM
Thanks for the reply. He believes there may be a short in the computer that is affecting the shifting problem also. He is checking on a kit made by GM to fix the tranny problem. We were not sure whether the map sensor code problem could affect the electronics for the tranny. Ever heard of the a kit for that? Maybe a new computer? Any ideas on costs associated with getting a new computer?
Again thanks for any input.
Tstown
11-20-2004, 05:32 PM
Forgot to mention, that tranny guy believes that the downshift problem probably burned up the tranny. He could not find anything inside that would have. Just thought I would mention.
BlazerLT
11-20-2004, 05:40 PM
Watch it, it sounds like they are going to blame it all on the MAP sensor.
Transmission will not be affected by a MAP error like that.
