Upgrades
austin944
11-16-2004, 12:07 PM
I am beginning to mod my 97 GTP. I have a CAI, replaced the snout bushing, autolite 103s, and new ac delco plug wires(my old ones needed to be replaced). I am torn between a PCM or smaller pulley. Which should I do first? Also which PCM should I go with. Is it better to by a smaller pulley or buy the Manguson nose drive with the 3.4 allready on there. Thanks!
SsHaDyGt
11-16-2004, 03:16 PM
I would go with the pulley before the pcm the pcm is said to require at least minimum modifications before installation about the new snout i heard it does improve something im not sure how? mabey someone could elaborate? some exhaust modifications should help also check out this link http://www.zzperformance.com/zzp/info/how_to_begin_mods_gtp.htm
kustomkid54
11-16-2004, 03:51 PM
Well the order I did it was;
3.4" pulley
Cold air box
PCM
And all the other mods stay unlisted.
http://img.photobucket.com/albums/v425/kustomkid54/1998PontiacGrandPrixGTP001.jpg
stlwagon
11-16-2004, 06:34 PM
Agree. Do the pulley first and then the PCM. I did u-bend delete, CAI, pulley, and PCM in that order.
kustomkid54
11-16-2004, 07:42 PM
The reason I picked the order that I did, was because when you put the PCM in you have to do a CKP Variation Learn/case learn. I wanted everything in place before I had to do that. Did cold air and pulley at sametime. Never had any troubles doing it that way.
But everyone has they way.
austin944
11-16-2004, 09:04 PM
But you don't have to do a case learn on a 97 right?
What is the best pulley to buy? Pulley boys zzp others?
stlwagon
11-16-2004, 09:20 PM
No case learn required as long as you swap the knock sensor from your stock PCM to the new one. I'm running a Pulley Boys 3.4 press-on. It's worked great so far.
