Headers Poll
david-b
11-15-2004, 01:18 PM
So after these crappy holidays are over, Ill be redoing thw WHOLE exhaust on my car. Headers, new cat, sensors, dual cat, everything! What do you guys think are better performance-wise? I'm looking for more lower rpm hp. Something to help me lauch better. Also has to be emissions legal. Thanks. Also, a link of some good headers would be appreciated. Thanks
anarchy1114
11-15-2004, 02:06 PM
if you do the whole exhaust system cool. but i would suggest that after you pass emissions get a bushur test pipe(machv.com) and its about 70 bucks. your cat bolts out , you bolt the test pipe back in and your set. as far as headers ... no clue whats better.
GTPSPEED
11-15-2004, 03:48 PM
try the holly airmass,,or check them out Airmass headers are built using state of the art four into one stepped tube technology. The Airmass header steps the primary tubes from 1-1/2" to 1/5/8" creating a very broad power curve. The four 16-gauge stepped primary tubes of the Airmass header merge into a single sequential fire collector. The sequential fire collector improves exhaust velocity resulting in increased horsepower and pressure wave tuning. Other features of the Airmass Pro-Step Header include machined Sealing Rings for leak free installation, long transition tubes for increased exhaust velocity and a design that allows for maximum ground clearance in lowered vehicle applications. so if you want go check them out im sure you can google them,ok my 2 cents thanks
david-b
11-15-2004, 08:16 PM
Sounds good. Oh yeah, i have a budget. Around $700 or so. Less is always better. I keep checking Ebay, and everything is so complicated. Whats good?
