1995 blazer spare tire
cubanlorenzo
11-15-2004, 12:08 AM
I have a 1995 blazer 4 door with the spare tire under the car. my problem is that one day i heard a rattle under my car. i thought that it was the spare tire. since i was only a mile away from home i thought i would check it when i got home. when i got there, i was missing my spare tire. a problem in my eye. i found the tire 1/2 mile away. the spare tire holder under my car snapped off. the wires holding the tire on. they all snapped. easy fix? or expensive dealer fix? or am i carrying my spare in teh back of the blazer? thanksin advance
JoulesWinfield
11-15-2004, 07:09 AM
I bought one on Ebay for like $35.00
It took maybe 45 min to change out. I think there is a total of 4 serews.
cubanlorenzo
11-15-2004, 11:52 AM
thats not that bad at all. what did you get with that purchase? the wires? or the whole set up?
JoulesWinfield
11-15-2004, 12:05 PM
It was actually the whole deal. Granted it was used but all I did was grease it all up before installing and it works fine.
SpectreSE
12-15-2004, 06:31 AM
I have a temporary donut on my 1997...anyone know if that wire and mounting assembly can handle the added weight of a full-size rim and 15" tire?
JoulesWinfield
12-19-2004, 11:23 PM
As far as I knew it was made for the full size spare. That donut must have been put there by someone other than the factory.
SlammedClipse
12-20-2004, 01:51 AM
mine came with a donut too...
JoulesWinfield
12-21-2004, 08:26 AM
Really???
Huh, maybe mine is supposed to have a doughnut also. I guess its possible.
So to SpectreSE the answer is: Yes, cause I have had a full size tire in mine for over 20k now.
Sunliner
05-12-2005, 10:19 PM
Reviving this thread to ask a question about the '97 Blazer (4 door, 2wd) ability to carry a full size spare on the underbody holder. Looks to me like the size won't be a problem but I don't know for sure about the weight.
Had a blowout last weekend & didn't like having to creep along the interstate on that donut...
-Mike
-Mike
SpectreSE
05-13-2005, 10:34 PM
Yes, I still have my doughnut spare under there, but wonder if the steel wire mounting assembly has only one version to accept the weight of doughnut vs. a fullsize rim and tire.
I can almost imagine hitting a good sized hole or bump, and the retention wire cable snapping off leaving my new aluminum wheel and full-size spare in the roadway...
JA no Y
05-14-2005, 12:35 AM
The spare tire mount should hold the weight of a full sized tire. Where else you gonna put the blown tire if you have a flat? My 95 Blazer has a full sized spare under it. It came with a full sized and It's been under my Blazer for the last 157k miles (thats the originals miles on the Blazer).
rlith
05-14-2005, 09:09 AM
Well my 95 uses a full size spare from the factory, so it shouldn't be a problem...
cubanlorenzo
05-14-2005, 03:41 PM
my 95 also came stock with full size spare, but i also had to replace the spare tire assembly becuase my wire holding it up snapped and i lost the spare tire but luckily i found it on the side of the road...
